Broadband backup dialup number?
wyerd
As my broadband connection is down and open reach can't fix the fault until Monday, I thought ill use the olde modem on a laptop but I can't find the number. Does anyone know? Thanks.
6 REPLIES 6
Fixes: 1,483
Re: Broadband backup dialup number?
According the connection settings in the portal it's 0845 1400101.
Whether it works or not I have no idea.
wyerd
Thanks.
wyerd
It works!
Fixes: 1,483
glad to hear it, hope it's quick enough to get done what you need Smiley
machare
When my broadband failed I found it quicker to use my mobile phone a a wifi hotspot
The dial up number I have is 0845 1422000
spraxyt
Resting Legend
Fixes: 75
I have that too; are you a Force9 customer?
David
