Broadband and Windows 95
shermans
Silly question but in a good cause !
A charity with which I work needs a laptop to be able to participate in a specialist forum - just like this one, so ntohing complex, or technically demanding or bandwidth hungry.
I have an old Windows 95 laptop which would be adequate for simple dial-up purposes, but I am not sure whether it would work with a wireless router.  Does anyone have any experience of that ?  Even if it were slow, would it work at all ?  I would have to buy a PCMCIA wireless card for it, but I have seen those on Ebay for just a couple of quid new, because they are basically redundant these days.
So any experience of Windows 95 (if you can remember those days) would be appreciated.  I don't want to waste time giving them this old laptop if it is not going to work.  But in principle, I don't really see why it should not.  I have tried it with broadband using a PCMCIA network card and it works well, but obviously not yet with a wireless card.  So the question relates only to the wireless side of things.
9 REPLIES 9
HPsauce
Re: Broadband and Windows 95
Your problem is going to be finding a suitable wireless card with drivers and a compatible mode to access the router.
I've got an old laptop that does work wirelessly. I believe it was initially Windows 98 (not 95) but I've updated it to ME.
The PCMCIA wireless card I use is a Cisco Aironet 350 (AIR-PCM352) and it only connects via 802.11b with WEP. I look after this very carefully as it took some finding.
I hope that gives you a few clues.
Peter_Vaughan
Does it have to be wireless?
You will have a better chance with a PCMCIA Ethernet card than a wireless card in terms of drivers but even so this may still be a problem as many manufacturers no longer have Win95 drivers on their website.
pierre_pierre
I actually got one from PN and asked for the lap top bits, got usb and PC card - BT version voyager 1065, trouble is min requirement win 98se, USB min Win 2000 or XP, and Voyager 2110
Peter_Vaughan
shermans
Thanks. I already have a pcmcia ethernet card which works absolutely fine - interesting, the old Pentium 160 processor with 48 Mb RAM and a 2 Gb hard disk seems to work as well as my latest XP machine ! But unfortunately for the charity's applocation, hard wire won't work - it  has to be wireless.  Howeevr, someone has a W98 wifi card who has offered to let me try it out.  It will be intersting to see the result.
samuria
With that spec of laptop it should run win98 and at a push win2k upgrading would possibly give you the drivers for the card if you cant get them for win95. You can get 98/win2k disk from the car boots £5 or less. The problem is its not worth bothering I dont know what its like in your area but around her you can get a pc with a 2 gig cpu for £20+ onthe car boot running xp and easy to get the drivers for.
shermans
I had not thought of that - probably even easier to look on Ebay !  I have a W98 CD anyway and so could reinstall if necessary.  But I think a car-boot or Ebay is probably the sensible answer - sad, because I am still very fond of that old Digital (DEC) 95 laptop !
HPsauce
With that spec it will also run ME quite happily; I've got an almost identical spec Dell doing so.
2000 might be pushing your luck a bit. Roll_eyes
MickKi
I would not advise going online with a Win95, or Win98 to be honest.  Neither of these were designed with the Internet in mind and from a security perspective they could be p0wned in seconds.  Sitting behind a router will of course offer some security, but not much (they open ports all over the place).  If you are really thinking of using this laptop then I would strongly recommend increasing the RAM to the maximum it will take and installing Win NT4, or Win2k.  You could also try installing a lightweight Linux distribution as per this thread which should be safer to connect to the Internet out of the box.
