Broadband Usage
- Broadband Usage
Broadband Usage
13-06-2013 7:56 PM
Plusnet fibre installed yesterday morning and the broadband meter shows 7.31gb for the day which is ridiculous. I downloaded a couple of large files for work, maximum of 1.5gb and then some fairly standard email traffic. No way it adds up to 7.31gb. Looks like I used about a gig overnight - midnight->8am, the wife watched a couple of programmes on iPlayer but again nowhere near a gig.
Today I'm showing 871mb, I've been out all day so that is pretty impressive.
Should I expect this thing to be anywhere near accurate?
Message 1 of 6
(1,028 Views)
5 REPLIES 5
Re: Broadband Usage
13-06-2013 8:07 PM
I find it to be pretty accurate when compared to the traffic meter built in to my router.
are you sure one of your devices aren't doing updates / etc?
do you have the wifi security switched on, on your router? make sure nobody is stealing your wifi!
Message 2 of 6
(520 Views)
Re: Broadband Usage
13-06-2013 8:09 PM
Just a thought on the Iplayer bit, with fibre its likely that Iplayer will have detected the increased bandwidth and given HD or at lease near HD steams this can easily add up to a couple of gig in an hour or so..
Message 3 of 6
(520 Views)
Re: Broadband Usage
13-06-2013 8:25 PM
I find the very opposite with the usage metering. I have frequently downloaded large amounts (films and catch-up) running well up the Gbs which register on Networx but sometimes don't seem to register on the 'view my broadband usage' page. Doesn't matter much as I am on unlimited, but I wonder why this is.
Democracy - 3 wolves and a lamb voting about what to have for lunch!
Message 4 of 6
(520 Views)
Re: Broadband Usage
14-06-2013 10:03 AM
It might be worth to make sure that your router has wireless security setup to make sure nobody else is piggybacking on your connection. Have a look through this guide to make sure all is OK.
Message 5 of 6
(520 Views)
Re: Broadband Usage
14-06-2013 11:47 AM
Thanks all, wifi is locked down.
I'm on unlimited so I guess it doesn't really matter, but I'll keep an eye on it.
Message 6 of 6
(520 Views)
