Broadband Still Dropping Out after Engineer Visit
- Re: Calculate Early Termination Fee
- « Previous
- 1
- 2
- Next »
29-04-2022 6:48 PM
An engineer any afternoon is fine thanks
29-04-2022 7:19 PM
29-04-2022 7:30 PM
Assume that last response is to me. Can you not right-click and copy?
02-05-2022 11:22 AM
02-05-2022 2:10 PM
@Aa65 wrote:
Yes. Done all the tests. Engineer came out and said the home set up was fine and that it was probably a line in/on the road and he would inform open reach.
This was after Plusnet email said they had run tests that showed no external problems.
Now have received an email from Plusnet telling me that the fault has been resolved
At times BT Openreach engineers will say anything to get out of the door.
There are issues which the BT provided test systems used by all ISPs will not detect and / or are not present at the time of testing (damp joints).
ISPs are obliged to close faults if lines test clear after a BTOR engineer visit. Such is why in some cases multiple engineer visits are needed - because BT Openreach fail to own problems with their own infrastructure.
- « Previous
- 1
- 2
- Next »
