Broadband Speed
- Broadband Speed
Broadband Speed
11-08-2012 7:08 PM
My broadband was activated yesterday and I set up my computer and router this afternoon.
My top speed seems to be 2meg (and this is my IP profile with BT) however I think I can get up to 8meg?
How does this happen, does my speed gradually get faster over the next couple of days?
Message 1 of 6
(1,018 Views)
5 REPLIES 5
Re: Broadband Speed
11-08-2012 7:20 PM
The BT IP profile should sort itself out in a day or so as you don't have 21CN ADSL2 available
Message 2 of 6
(533 Views)
Re: Broadband Speed
11-08-2012 7:27 PM
Thanks for your reply.
Do I need to do anything (like reboot the modem router) to pick up the changes?
Message 3 of 6
(533 Views)
Re: Broadband Speed
11-08-2012 7:33 PM
I don't think so.
But if nothing has happened by tomorrow a single disconnect / reconnect of the router (you can just unplug it from the phone line, leave it for 5 mins and then plug it in again)
Given your excellent speeds this won't have any side effects if you only do it omce
Message 4 of 6
(533 Views)
Re: Broadband Speed
11-08-2012 7:58 PM
I vagually recall that all new ADSLmax connections (20CN system) are automatically set initially to a profile of 2.0 by BT.
The profile then adjusts as appropiate up/down.
Don't know the time scale for this.........I suspect Jim is right when he says 'a day or so'
Message 5 of 6
(533 Views)
Re: Broadband Speed
11-08-2012 8:00 PM
Thanks everyone for your help!
Great support here!
Great support here!
Message 6 of 6
(533 Views)
