Broadband Speed
AMM
Broadband Speed
I'm currently only getting 1.2Mbps on our Plusnet Broadband :-( See the link below to the speed check results.
Pleas can you contact me to let me know how this will be addressed.
Many thanks
https://gigaclear.speedtestcustom.com/result/05850a80-20b3-11e8-ad77-1bc1d3ffb4f2
1 REPLY
Fixes: 411
Re: Broadband Speed
Welcome to the community forums.
Sorry to hear you're having speed problems.
It looks like you've contacted us last night and we've reset your line. How have things been since then?
Our tests are showing your router in sync at 3.5mbps which is within expectations for your line.
