Broadband Speed
thedoors27
Broadband Speed
Hi everyone, fairly newish plus.net user here.
My details are as follows :-
Phone exchange:
    CLEVEDON
Estimated line speed:
    79Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-12-17 17:37:51
Current line speed:
    78 Mb
When I use a broadband speed checker it is only saying 26Mb upload speeds varies from 9Mb to 10Mb. I've used Ooklas and BTs speed checker both results pretty much the same.
thesawdust
Re: Broadband Speed
can you run http://speedtest.btwholesale.com then click further diagnostic then tell us what IP profile is set too?
thedoors27
Re: Broadband Speed
1. Best Effort Test: -provides background information.
Download Speed
27.79 Mbps
0 Mbps 74.21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 27.79 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-74.21 Mbps .
Additional Information:
IP Profile for your line is - 74.21 Mbps
Upload Speed
7.9 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 7.9Mbps
Fixes: 162
Re: Broadband Speed
Is that a wired or wireless speedtest? If wireless, what speed do you get with a cable?
 Chris Parr
 Plusnet Staff
thedoors27
Re: Broadband Speed
Wireless.
Fixes: 54
Re: Broadband Speed
As connection speeds will usually be slower over wireless than over a wired connection do you have a network cable you could use to connect between your PC and router? If so can you run us another test that way as it would help us understand if the drop in speeds is due to the connection itself or the wifi connection.
 Adam Walker
thedoors27
Re: Broadband Speed
Results of wired test
Download Speed
67.42 Mbps
0 Mbps 73.93 Mbps
Download speedachieved during the test was - 67.42 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-73.93 Mbps .
IP Profile for your line is - 73.93 Mbps
Upload Speed
10.88 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 10.88Mbps
So the line speed and estimated line speed of 78/79Mb should be ignored?
Fixes: 10
Re: Broadband Speed
Try this speed test: http://www.thinkbroadband.com/speedtest.html - it tends to be more accurate than the BT one.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
thedoors27
Re: Broadband Speed
thedoors27
Re: Broadband Speed
Are my speeds acceptable for what I'm paying for?
thesawdust
Re: Broadband Speed
Yes speeds are acceptable i'd say  Wink
