Broadband Speed and SNR Margin
- Broadband Speed and SNR Margin
14-02-2012 11:16 PM
I only got my new phone line and broadband a couple of weeks ago. It started off with a constant 2mb connection which is acceptable due to my distance from the exchange. I had a few occasional disconnects, a couple a day, but it didn't last long and wasn't really a problem. The thing, is I notice my download speed has fallen every time the line disconnects/reconnects and now sits at 1.5mb. This is a bit slow for my needs. The SNR Margin has fallen from about 9db to 12.5db which probably explains the lower download speed. Also there were a couple of times this evening when I had a power cut in my house and that contributed to the noise margin falling.
I am using an old Speedtouch 580 router (didn't think there was a need to upgrade), and connect directly to the master socket.
Here are some stats:
Link Information
Uptime: 0 days, 0:36:20
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,952
Data Transferred (Sent/Received) [MB/MB]: 2.80 / 10.67
Output Power (Up/Down) [dBm]: 12.5 / 16.5
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 14.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): 0 / 2,165
CRC Errors (Up/Down): 0 / 9
HEC Errors (Up/Down): 0 / 2
Thanks in advance for any help you can give!
Re: Broadband Speed and SNR Margin
15-02-2012 8:24 AM
How is your kit set up? Are you using any extension cables/sockets? Do you have a test socket? I could set the SNR down to 6dB but unless we find out why it's raised then it can be quite fruitless.
Jojo
15-02-2012 11:18 AM
E.g. http://www.ebuyer.com/113906-apc-back-ups-es-400-ac-230v-400va-8-output-connectors-be400-uk
15-02-2012 2:31 PM
Thanks for your reply. Basically my kit comprises of a master socket with a 7 metre extension cable, and from there it is plugged into the router via high quality microfilter. I'm sure I do have a test socket although I have never tried it! How would I know if it works? Do I have to leave it in the test socket for any length of time?
The wiring in my house is all brand new, and I made sure I bought high quality connection cables to give me the best chance of success. The only thing that is old is the router. I don't have another one to try, but it is possible I could borrow one as a last resort.
And thanks Jelv, that UPS idea is great, might have to invest in one! I live in the countryside so I am prone to power cuts.
15-02-2012 2:47 PM
15-02-2012 3:04 PM
You really could do with putting it into the test socket. Using extensions can cause big trouble and I certainly wouldn't suggest resetting the SNR while the set up is like that.
Jojo
15-02-2012 3:39 PM
Jojo....I understand your point. How long do I have to leave it in the test socket for?
15-02-2012 3:40 PM
15-02-2012 3:45 PM
Quote from: mike0381 I didn't know that flat extension cables can cause problems. When I bought it however, flat is the only type I could find, couldn't find a twisted pair one!
Put the filter in to the master socket and then buy something like this to replace the filter to router cable: http://www.ebay.co.uk/itm/10m-ADSL2-High-Speed-Broadband-Modem-Cable-RJ11-/380326860445?pt=UK_Comput...
15-02-2012 4:44 PM
For now I have found a temporary home for the router and plugged it (with microfilter) directly in to the test socket.
15-02-2012 5:13 PM
I'll reset it now then, can take 24 hours, so I'll see if it's worked in the morning for you.
Jojo
15-02-2012 7:02 PM
I know the line attenuation of 61db doesn't help. It seems to go between 60 and 61.
And the SNR has now just gone from 6.5db to 10db.
Thanks again for all your assistance with my problem Jo.
16-02-2012 8:55 AM
Uptime: 0 days, 14:31:15
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,888
Data Transferred (Sent/Received) [MB/MB]: 65.59 / 585.26
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 61.0
SN Margin (Up/Down) [dB]: 14.0 / 14.5
Error Seconds (Local/Remote): 356 / 0
FEC Errors (Up/Down): 0 / 7,060,084
CRC Errors (Up/Down): 0 / 3,168
HEC Errors (Up/Down): 0 / 339
16-02-2012 9:13 AM
16-02-2012 9:44 AM
I have done the quiet line test, it seems pretty quiet. What noise am I actually looking out for? Is it a particular kind of noise? Please note I only have a cordless phone. Haven't owned a corded one for many, many years!
