Broadband Speed Issues - pmxyz - split
pmxyz
1) PlusNet Broadband Your Way Option 2 with included 15GB bandwidth
2) Paid-for usage  94.56MB
Paid-for allowance: Up-to 15GB
Free usage: 672.68KB
Total usage: 95.23MB
3) Current line speed: 250
4) This is from last night *
Download speedachieved during the test was - 125 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :192 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
5) Not available at present.
6) VP capacity at this exchange is currently showing as Green - LWGAR
7) This is happening frequently and has been for the last 3 months. Never used to happen before.  Something has defiantly changed. Clearly other users are having similar issues. Ticket already open.
* looks like the profile it dropped again overnight. Great!
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Broadband Speed Issues - 03/10/09
@pmxyz
You aren't experiencing the same issue as the other people in this thread, your slow speeds are caused by your profile dropping due to a low sync on your line. Make sure your modem/router is plugged in to the master socket without using an extension lead, if your sync increases it should take around 3 days for your profile to increase and then you'll see better speeds.
 Chris Parr
 Plusnet Staff
