Broadband Showing No Usage
Alex_Hamilton
I cannot see my broadband usage.  "Nothing to show" message, which cannot be true.
What is happening?
SpendLessTime
Aspiring Hero
Fixes: 67
Re: Broadband Showing No Usage
If you are on a tariff where you have a limited GB traffic per month then log a fault.
If you are on an unlimited account then Plusnet have disabled usage on their new network for selected gateways. This is due to errors on those gateways.
Search for usage on the forum search, you will find plenty of topics about this.
SpendLessTime
Aspiring Hero
Fixes: 67
Fixes: 68
Hi Alex,
I can arrange this for you. I'm able to generate hourly or daily figures so let me know which might help you.
 Adam Walker
Alex_Hamilton
Thank you Adam. I usually check my usage once or twice a day and after viewing and/or downloading programmes.  I appreciate that there always is a time lag between usage and it showing the usage.  I was happy with what we had before, so is it possible to restore that?
Many thanks,
Alex
Plusnet Staff
Plusnet Staff
Fixes: 117
For unlimited accounts I'm afraid not. However I've looked into your account and I can see the account type does not include unlimited usage so you should be able to view this normally via the Member Centre.
Can you reboot your router for me please then let me know if the usage monitor works/doesn't work still?
Thanks.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Fixes: 68
Hi Alex, I've added your usage so far today to ticket 144203939 for you in case that helps.
 Adam Walker
Alex_Hamilton
I have rebooted, but it still does not show - 13.50hrs.
Thank you again for trying.
Alex
Plusnet Staff
Plusnet Staff
Fixes: 117
As you're on a limited product I've raised a ticket to our Networks team to investigate this within the next 1-3 working days. In the meantime, Adam's posted some of the usage on your account.
 Plusnet Staff
Alex_Hamilton
Thank you Anoush.  It is back to normal now and I cannot thank you enough for doing this for me.  It was like driving a car with the fuel gauge not working!!!
Thanks again,
Alex
Plusnet Staff
Plusnet Staff
Fixes: 117
Fantastic news, thanks for coming back to let us know.
 Plusnet Staff
