Broadband Question
MegaPixelMan
Broadband Question
I've just had an engineer out to install/activate my phone line.
I am aware that I now have to wait 5-7 days for the router and the broadband to be activated.
My question is now the engineer has finished, do I need to contact customer service to let them know? Or will you guys know everything is now connected?
(P.S. I hope this is in the right place xD)
OFF TOPIC QUESTION - My Plusnet Assist doesn't seem to be working with Windows 8. Is there a fix for this?
Fixes: 10
Re: Broadband Question
I'm not aware of any of the experienced users on here that would dream of using Plusnet Assist. There's nothing it does that can't be done manually. I suggest forget it - if you have queries post back here and someone will help.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MegaPixelMan
Thanks for the reply.
I wanted to get everything sorted for when my router is delivered and broadband is activated. But if I don't really need it I won't bother, thank you for letting me know.
Fixes: 71
Quote from: MegaPixelMan
The line installation and phone activation results from an order that Plusnet place on BT Openreach. When the order completes Plusnet should be informed, and I would expect them to send a text message (and email if an address has been provided) to let you know.
So no need for you to tell them. Smiley
David
