Broadband Query
- Re: Broadband Query
Broadband Query
08-02-2013 7:36 PM
I have BT Openreach coming around on 22/2/13 to do the Fibre install.
I just a text from Plusnet stating my service will be active by midnight 23/2/12
Now I was informed with the transition from Sky landline and Broadband to Plusnet Phone and Fibre BB there wouldn't be any downtime...or a maximum of 2 hours...is this the case or will I experience more downtime?
Re: Broadband Query
08-02-2013 7:53 PM
Quote from: jaym0nd Now I was informed with the transition from Sky landline and Broadband to Plusnet Phone and Fibre BB there wouldn't be any downtime...or a maximum of 2 hours...is this the case or will I experience more downtime?
I think the answer is probally Yes
Re: Broadband Query
08-02-2013 8:00 PM
But is this generally the case with a transition with LLU to FTTC?
Re: Broadband Query
08-02-2013 8:03 PM
You will get about what you expect, about 2 hours down time unless something out of the ordinary happens then all bets are off.
Re: Broadband Query
08-02-2013 8:06 PM
Re: Broadband Query
08-02-2013 8:09 PM
Re: Broadband Query
08-02-2013 8:15 PM
Re: Broadband Query
08-02-2013 8:24 PM
However I was on Be LLU. 3.5 Km from exchange and got 7MBps on ADSL2+ Which was about right for the distance and my reported attenuation. I am now 280m +/- 50m from my fibre box (I found another one I thought I was 900m from it originally) and my estimated speed was 62Mbps down 20Mbps up. I actually get 73/73Mbps down and 17Mbps up. So I guess there is certainly hope, but I think it depends on where your FTTC cabinet is.
Re: Broadband Query
08-02-2013 9:33 PM
Re: Broadband Query
09-02-2013 1:08 AM
Quote from: tijara33 As a rule of thumb, deduct 10 Megs per 100 kms.
Erm don't you mean meters?
Re: Broadband Query
09-02-2013 6:13 AM
Quote Erm don't you mean meters?
Woops. Too much Friday night red wine!
Re: Broadband Query
09-02-2013 1:56 PM
The big green one is around 0.25km walk or drive away and a smaller one probably 30-50m away from our house.
Re: Broadband Query
09-02-2013 6:30 PM
Go here https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch... and check which cabinet you are on then look for numbers on the big green cabinets.
One issue to be aware of is if you are in a virgin cable area they also use green cabinets and it does make it harder to work out which ones are BT or not.
Re: Broadband Query
11-02-2013 10:14 AM
Your services will go active on the 22nd, it's an automated message you've received that states the day after, something we're currently looking at.
