Broadband Product Change
grahamn
I used the product change facility this morning to change my PlusNet Broadband package, but so far I've had no email to acknowledge the change and when I go in to view the product, it makes no reference to the product change that I requested.
Is this normal, as I'm wondering if the request worked and is in the "the system"?
Many thanks,
Graham.
Fixes: 10
Re: Broadband Product Change
It will be in the system and will only come in to effect on your next billing date.
There should be a closed ticket on the account about it I think.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Hi Graham,
Your account is scheduled to change on the 8th November.
If there's anything else your unsure of ask away Smiley
Chris
grahamn
Hi Jelv and Chris,
Many thanks to you both for your replies.
Good to know it's in the system and due on the 8th as expected.
Regards,
Graham.
Grff
I changed mine a couple of days ago to fibre, and the only thing I got was an email regarding the engineer appointment.  I don't see anything else on my account other than the payment change in the billing section.
@Griff
Your fibre appointment is still on track for a week today, your account product will change over to fibre on that date.
