Broadband Not working
Jamie37
It says connected and the blue light is on the hub one but it doesn’t work. I don’t know if this is because the bill was payed late or what please help?
8 REPLIES 8
Fixes: 1,600
Re: Broadband Not working
Hi there.
If you can send me a PM with your username I'll be happy to look into this.
Fixes: 1,600
Thanks for the PM.
Can you factory reset your router by pushing a paperclip into the reset hole at the back for 20 seconds?
Let us know how you get on.
Jamie37
Done that Now the light is orange with orange brodanband light
Jamie37
Sorry it’s now blue Again and when you go to connect it says log in and brings you to the 192. Page thing and says log in but nothing to log in to
Fixes: 1,600
From what I can see your router is trying to connect using the wrong password.
Can you try the below steps?
1. Open an internet browser and type http://192.168.1.254 into the address bar
2. Press the 'Enter' or 'Return' key
3. Click on 'Advanced Settings'
4. Enter the admin password, which is on the back of the router
5. Click on 'OK'
6. Click on 'Continue to Advanced Settings'
7. Click on 'Broadband'
8. Click on 'Disconnect' if necessary
9. Enter your broadband username, which is in the format of yourusername@plusdsl.net
10. Enter your broadband password, which is your account password
11. Click on 'Connect'
Jamie37
Just done this and it just says ppp connecting and goes back th the enter broadband details again
Jamie37
Sorry I don’t think it’s the right password and I can’t chose another one right now
Fixes: 1,600
No worries.
Once you know the password you should be able to connect.
