Broadband Network
fatimab06
Broadband Network
my internet has been really unreliable. Almost every two months, it gets shaky and barely works for about a week. It's incredibly frustrating.
I thought things would improve after an engineer came out to fix it, but the problem is still the same. Can you please look into this urgently? I really need a stable internet connection.
Thanks for your help.
6 REPLIES 6
Anunnaki
Re: Broadband Network
@fatimab06  try reporting a broadband fault by text, using the following instructions -
zpeterk
If you are on Sogea texting won’t work, you will have to phone
Anunnaki
@fatimab06
If you have to phone in to report a broadband fault (if first sending the HELP text fails), then here is the number -
Champnet
Fixes: 21
Reading the first post @fatimab06  has already been down the standard route.
what is needed is for Plusnet to pick up this thread and escalate the problem.
Anunnaki
... but that was probably September 2023 ?  -  Experiencing issues with my broadband
Unfortunately getting Plusnet staff to 'pick up' a thread these days is easier said than done 🙄
@fatimab06
Have you used the complaints procedure? See https://www.plus.net/help/legal/complaints-code-of-practice/
