Broadband Max
- Re: Broadband Max
Broadband Max
25-08-2007 4:46 PM
Hi there, I opted into Broadband Max back in May. Still no increase in speed. Can anyone help?
Regards
Ian
Regards
Ian
Message 1 of 6
(1,738 Views)
5 REPLIES 5
Re: Broadband Max
25-08-2007 5:00 PM
You're already on Max, can you let me know what a BT Speedtest gives you?
Message 2 of 6
(521 Views)
Re: Broadband Max
25-08-2007 5:20 PM
Hi Mand, it was the opt in for upp to 8meg I meant, my speeds are these;
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1965 kbps
Message 3 of 6
(521 Views)
Re: Broadband Max
25-08-2007 5:25 PM
I've made some changes to your account. If you'd like to reboot and try again for me you should see a difference.
Message 4 of 6
(521 Views)
Re: Broadband Max
25-08-2007 6:16 PM
Hi Mand, thanks for your quick reply, here are the new test results.
Actual IP throughput achieved during the test was - 889 kbps
I am under level one management at the moment.
Ian
Ian
Message 5 of 6
(521 Views)
Re: Broadband Max
26-08-2007 2:43 PM
Hi Mand, speeds have improved, thanks very much.
Actual IP throughput achieved during the test was - 4161 kbps
Ian
Ian
Message 6 of 6
(521 Views)
