Broadband Fault Checker
- Broadband Fault Checker
19-09-2007 10:34 AM
I have been asked to run the Broadband Fault Checker due to a speed issue. The programme requires my firewall to be shut down during part of the process and i really don't wish to do that. If this is really necessary then i will have to comply in order to allow the checker to complete its tests.
I would like some advice on the subject before going ahead, thanks to all who respond.
Fogies.
Fogies.
Message 1 of 7
(2,632 Views)
6 REPLIES 6
Re: Broadband Fault Checker
19-09-2007 10:41 AM
If you've been asked by a member of staff to do it and it's one they told you to use, then turning your firewall off for a few minutes really won't cause you problems.
Message 2 of 7
(815 Views)
19-09-2007 10:42 AM
The recommendation is to lower your firewall briefly as this is often the cause of many issues.
Just try it briefly and if it doesn't help, then simply turn it back on again.
Message 3 of 7
(815 Views)
19-09-2007 4:23 PM
FWIW I think Plusnet probably ought to review that part of the fault checker, since XP really shouldn't be exposed to the net directly without at least Windows Firewall, which appears nearly transparent anyway.
Message 4 of 7
(814 Views)
19-09-2007 4:48 PM
With software firewalls and antivirus still being problematic with loss of data transfer that would potentially eliminate a crucial form of troubleshooting for a number of broadband faults.
Message 5 of 7
(814 Views)
26-09-2007 11:24 AM
Appreciated, thats why I said review and not remove.
Message 6 of 7
(814 Views)
26-09-2007 1:17 PM
If the fault checker requires the opening of certain ports, why not just say what they are?
Message 7 of 7
(814 Views)
