turn on suggestions
Broadband Fault Checker won't work with Opera 10 natively
- Broadband Fault Checker won't work with Opera 10 n...
27-09-2009 11:38 AM
I've just been asked to initiate the Broadband Fault Checker as part of a ticket I've raised about a speed problem (see also my thread here)
I'm using Opera 10 under Windows XP Home SP3.
I can open the fault checker OK, and it returns the page asking if the telephone number etc. is correct ... but when I click on "Yes", the page simply refreshes rather than taking me on to the next stage.
If however I use Firefox or IE, or if I set Opera to masquerade as Firefox or IE, then the page continues OK.
This is disappointing and annoying.
Re: Broadband Fault Checker won't work with Opera 10 natively
28-09-2009 1:57 PM
Has Opera 10 actually been released officially yet?
I thought it was still in beta?
28-09-2009 2:01 PM
nope it's live and fully released -- Opera users on earlier versions receive prompts to upgrade
28-09-2009 2:05 PM
Thanks Paul.
Any chance you could grab me a screengrab? I'll be able to raise it with the content team to see if there's anything they can do.
28-09-2009 2:22 PM
yessum, but it'll only show the page looking normal -- it's the action that's the problem
(or perhaps it's that I've described it so inadequately you want to know where the problem occurs
usually the problem with this sort of apparent Opera-incompatibility is that pages are coded for IE's quirks (even though the coders don't realise they're quirks). FF seems to be able to manage this on-the-fly whereas Opera executes code on the basis of "the standard" (unless you explicitly tell it otherwise) and so appears to fail.
anyhoo, i'll sort it when i get home
28-09-2009 6:20 PM
umm can't ... not until the fault is closed anyway, 'cause the checker won't let me open another check
