Broadband Disconections
Alex2x
Everyday now my Fathers broadband is disconnecting and it stays disconnected for some time. I noticed that there is problems with the network in some areas.
Can you check if the town Mauchine in Ayrshire is having problems.
Thank you .
Alex..
1 REPLY
Re: Broadband Disconections
Can't see any known issues in that area, unless his neighbours are affected as well it's likely a line fault and should be tested and raised as per http://faults.plus.net - that'll raise a ticket to our faults team who'll get things sorted for him.
