Broad fault checker "out of service" for maintenance
Fixes: 12
As the title, but no Service Status, although a message does appear once you're part way down the path?
The holding page https://portal.plus.net/apps/kbdfaults only quotes the 0845 number to contact support,  this needs updating please
Maurice
1 REPLY
LukeS
Re: Broad fault checker "out of service" for maintenance
Thanks for flagging this, I will ensure the number is updated for the next time the holding page is required.
The outage is mentioned in the announcements section of the service status page. Everything should be up and running by 5pm.
