Broad fault checker "out of service" for maintenance
- Broad fault checker "out of service" for maintenan...
19-07-2014 12:43 PM
As the title, but no Service Status, although a message does appear once you're part way down the path?
The holding page https://portal.plus.net/apps/kbdfaults only quotes the 0845 number to contact support, this needs updating please
Maurice
Maurice
Message 1 of 2
(441 Views)
1 REPLY 1
Re: Broad fault checker "out of service" for maintenance
19-07-2014 3:17 PM
Thanks for flagging this, I will ensure the number is updated for the next time the holding page is required.
The outage is mentioned in the announcements section of the service status page. Everything should be up and running by 5pm.
Message 2 of 2
(224 Views)
