Broad band speed to fast
- Re: Broad band speed to fast
27-06-2008 11:53 PM
22/12/07 4736 syn speed
12/01/08 4672
29/01/08 4608
7/02/08 4480
Now in the last few days it gets faster every day
22/05/08 5184
23/05/08 5312
24/05/08 5152
25/05/08 5184
26/05/08 5280
27/05/08 5408
No changes to equipment no dramatic change in weather so why suddenly has it got better?
28-06-2008 9:11 AM
28-06-2008 11:02 PM
Modem Status today
Connection Status Connected
Us Rate (Kbps) 448
Ds Rate (Kbps) 5440
US Margin 26
DS Margin 9
Trained Modulation GDMT
LOS Errors 0
DS Line Attenuation 48
US Line Attenuation 29
Peak Cell Rate 1056 cells per sec
CRC Rx Fast 0
CRC Tx Fast 0
CRC Rx Interleaved 125
CRC Tx Interleaved 6
Path Mode Interleaved
29-06-2008 10:46 AM
29-06-2008 2:41 PM
Quote from: samuria No changes to equipment no dramatic change in weather so why suddenly has it got better?
I think you will find that the cold, damp weather in January and February cannot be compared to the relatively warm, dry weather in May/June. Other than that previous comment on possible work on the line connections by BT may have something to do with it?
30-06-2008 12:09 AM
30-06-2008 10:28 AM
Quote cannot be compared to the relatively warm, dry weather in May/June
Wish I lived where you do! But it's a valid point, when the weather is decent, any potential dampness causing poorer sync speeds will have dried out potentially improving the speeds of the connection.
30-06-2008 11:10 AM
Being "typically english" I suppose any "unknown" is blamed on the weather !
30-06-2008 11:13 AM
That's why I was careful to use "potentially"
Your problem obviously wasn't attributed to the weather. But it is possible for underground cabling to be affected by periods of wet weather, to be subsequently resolved when the cabling dries out.
We can't all live in the sunny south you know
30-06-2008 11:14 AM
On a decent quality line, weather will have little effect.
On a marginal quality line the weather can have drastic effects. In the case where there may be an exposed joint in the cabling, damp weather can certainly exacerbate an existing problem. Also, a lot of telephone lines are run in underground conduits. If these are prone to leaking then you can end up with a completely submerged line. While this won't cause any problems with a correctly insulated line, older lines which may be suffering from perished insulation can certainly start to see problems!
B.
30-06-2008 11:24 AM
OR... the lines around here are in "excellent" condition, and cannot be improved with a bit of sunshine....
Just a point to note....
If rain can penetrate the ground to a depths of 18" and cause cables to be "damp", how far does sunshine penetrate (?) and how long does it take for that sunshine to dry them out again?
30-06-2008 11:14 PM
Quote from: shutter OR... the lines around here are in "excellent" condition, and cannot be improved with a bit of sunshine....
You got it!
Quote from: shutter Just a point to note....
It's not the water per se, but the condition of the insulation. If the insulation is good then it is impervious to dampness and you'll see no difference in its performance. On the other hand, if it is like mine . . .
01-07-2008 8:00 AM
My downstream speeds have also been increasing since Christmas and have now stablised to 6976/448. I have not done any improvements to explain this.
The plots of ADSL show Channel show an across the board inprovement in bit capacity per channel.
Have a look at http://www.dougrice.plus.com/Erlangs/a_specLatest.png
01-07-2008 8:13 AM
With regard to your increase in sync speeds, maybe OpenReach have improved some cabling on route, or local noise factors have reduced for some reason.
01-07-2008 8:45 AM
