Broad band extender Netgear WNDAP350
- Broad band extender Netgear WNDAP350
27-11-2012 10:01 AM
Can anyone please advise of any settings that need to be changed on the Plus net router to accomodate my netgear extender. Ive used itfine for the last 12 months with BT but since ive switched to plusnet its very tempremental, we have to keep logging in and out to get signal.
Many Thank
Luke
Many Thank
Luke
Message 1 of 3
(736 Views)
2 REPLIES 2
Re: Broad band extender Netgear WNDAP350
27-11-2012 10:07 AM
Probably because the wireless range of your Plusnet-supplied router isn't as good as BT one so you need to move the extender closer to the router. You can set-up a BT Home Hub to work with Plusnet, you know.
Message 2 of 3
(386 Views)
27-11-2012 10:29 AM
Thanks for the prompt response but the wifi extender is wired to the other side of the house via cat 5E
Message 3 of 3
(386 Views)
