Brief losses of the Internet.
YorkshireTyke
I have been keeping a log of my brief losses of the Internet. I have a wired connection to my plusnet Hub 2 router. The Internet is lost for less than a minute each time. So far the Internet has been lost on the following days & times:-
2024-09-23 @ 06:49-06:50 & 18:02-18:03
2024-10-08 @ 08:08-08:09 & 08:13-08:14
2024-10-10 @ 09:10-09:11
2024-10-12 @ 12:05-12:06 & 12:07-12:08 & 12:16-12:18 & 12:19-12:23
2024-10-13 @ 08:48-08:49 & 08:54-08:55 & 08:56-08:57 & 08:58-08:59
Any suggestions as to whether it's a fault with the router/power supply/Internet provider?
Tags (1)
13 REPLIES 13
Fixes: 334
Re: Brief losses of the Internet.
@YorkshireTyke Is this also affecting/changing your connection speed? Bald , unconnected figures do not really give us much to go on.
Maybe export  your Event Log and attach it to a reply, and someone may be able to offer advice.
Tags (1)
YorkshireTyke
Hello John, please find attached the event log. Sadly it doesn't mean anything to me.
Tags (1)
Fixes: 334
Fortunately, it is helpful to me. 😉 . From a quick look, you are suffering from numerous DSL drops. I would suggest you report a fault, but before you do, a quick question - do you still have a landline connected, or are you on SoGEA?
Tags (1)
Champnet
Fixes: 18
The loss of internet times seem to correspond to denial of service attacks.
Tags (1)
Fixes: 124
I get denial of service messages very often with no loss of service
@YorkshireTyke
Have you upgraded recently on or around the 31st August
11:16:29, 02 Sep. DSL Link Up: Down Rate=42966kbps, Up Rate=8214kbps; SNR Margin Down=6.3dB, Up=6.2dB
19:18:42, 31 Aug. DSL Link Up: Down Rate=40000kbps, Up Rate=9997kbps; SNR Margin Down=12.7dB, Up=9.0dB
There's been a significant change in the SNR margin, which suggests a change or a fault
Tags (1)
YorkshireTyke
The broadband package I signed up to was "Fibre SoGEA" so no landline phone.
Tags (1)
YorkshireTyke
I do not know of any upgrade. So would that be an upgrade to my router?
Tags (1)
Fixes: 334
Analysing the log, the OP is suffering constant DSL drops.
@YorkshireTyke As you are on SoGEA, the auto-bot will not help here, I suggest you call in and report a fault - let us know the result, please.
Tags (1)
Fixes: 124
Sorry, should be clearer, have you changed from Unlimited Fibre with phone to Fibre without phone.
Which everyway you need to raise a fault as that many DSL drops is wrong.
I also have looked at the event log!
Tags (1)
YorkshireTyke
Thank you guys for your suggestions, I'll report a fault later today as I have a zoom meeting now.
Tags (1)
YorkshireTyke
I'm now expecting an engineer on Tuesday morning, so I'll report back after their visit. Thank you again for your help.
Tags (1)
YorkshireTyke
The BTopenreach  engineer arrived this morning and replaced my external phone cable, as the old one was damaged due having been left loose across a flat roof so suffered from chafing.
Tags (1)
Fixes: 334
Has it solved your problem?
Tags (1)
