Bought MID tablet early december,cannot conect Wifi
- Bought MID tablet early december,cannot conec...
17-01-2012 12:02 PM
After many days and tech advice it was found on 21 dec my line was not correct and they rectified and i was conected for 20 hrs that was it they then told me that the alteration to my line takes 10 days
to settle in just the same and keep getting same instructions from plusnet how to sort it out, i have done all of these time time again again, i can use my tablet at all others homes and my gson was here
when i had my magic 20 hours and his ipad worked then only at my adddress.
hope there is somebody out there can help
lennylegger
lennylegger
Message 1 of 2
(617 Views)
1 REPLY 1
Re: Bought MID tablet early december,cannot conect Wifi
17-01-2012 1:00 PM
Hi risca,
It's not easy to suggest possible reasons for that, not having any experience myself with a MID tablet. Can you give some more information please? What happens when you try to connect? Does it ask you for the wireless password? Can you see the router in available networks. If you can give as much detail and step-by-step what happens when you try to connect we may be able to get more of an idea.
Jojo
Jojo
Message 2 of 2
(284 Views)
