Blueyonder address not getting my emails
- Blueyonder address not getting my emails
07-07-2008 1:56 AM
I'm getting messages from my sister, but she is not getting replies, and I am not getting FTD notifications. She has checked her Outlook blocked-sender list and her webmail account to no avail.
Are we blacklisted? Any thoughts?
Chris
Re: Blueyonder address not getting my emails
07-07-2008 6:57 AM
07-07-2008 9:23 AM
Quote from: ChrisL Are we blacklisted? Any thoughts?
I'd expect a failed delivery notification even if our relays were blacklisted. We've eight relay servers in total and it would be very unusual for all of them to have ended up on a blacklist. What happens if you try sending the message via Webmail? This uses the cgi-relays to deliver the message so provides an alternate route. Might help us narrow down the cause of the problem.
07-07-2008 2:47 PM
Bob, I will try sending via webmail. It may take a while to find out if that hasn't worked. I've thought all along that the problem was with my sister's set-up, but we're clutching at straws now!
07-07-2008 8:58 PM
08-07-2008 1:20 PM
I've tried sending a few messages myself to some Blue Yonder addresses and will check tonight to see if they've arrived (I won't be able to get in touch with the recipients until then).
I've also sent the following email to your sister via pih-relay08.plus.net. Perhaps you can find out whether or not she received it?
bpullen@pvs-csctools:~$ telnet relay.plus.net 25
Trying 212.159.11.46...
Connected to relay.plus.net.
Escape character is '^]'.
220 relay.plus.net ESMTP Exim Tue, 08 Jul 2008 13:15:32 +0100
helo relays
250 pih-relay08.plus.net Hello relays [84.93.217.165]
mail from:support@plus.net
250 OK
rcpt to:xxxxxxxx@blueyonder.co.uk
250 Accepted
data
354 Enter message, ending with "." on a line by itself
subject:This is a test email sent from Plusnet Support
Testing mail delivery via pih-relay08.plus.net
250 OK id=1KGC72-0007nD-1l
quit
221 pih-relay08.plus.net closing connection
Connection closed by foreign host.
08-07-2008 3:31 PM
09-07-2008 11:48 AM
Is it just replies to her emails that don't arrive or is the same problem encountered when you send a fresh email.
Do *any* of the emails you send arrive in her Inbox?
The fact your sister received my test email certainly suggests there's no problem with the relays (well certainly not pih-relay08.plus.net).
09-07-2008 6:32 PM
Regards.
10-07-2008 12:13 AM
I've sent you a PM with headers from a message I received. There's nothing obvious wrong with the return address.
I'm about to try a new message, rather than a reply, because all my emails since the problem started have been replies. Nothing has got through since 2nd May -- we're talking about 8 - 10 messages. (Except for the webmail, of course!) It'll be late tomorrow before I know whether the new message has got through.
@Anotherone
Yes, thank you for your interest, it does help by elimination to know your emails are arriving. (Grrrr!!)
Chris
10-07-2008 9:41 AM
10-07-2008 3:11 PM
Chris
10-07-2008 11:52 PM
But if Blueyonder is incompetently using Spamhaus blacklisting I should still get a bounce, shouldn't I?
Is there a channel of communication with another ISP to correct this kind of mistake, or do I need to request a static IP?
11-07-2008 4:11 PM
Quote from: ChrisL It might be another case of this problem with dynamic IP?
I'm beginning to think it is because of your dynamic IP. spraxyt has been helping me test this. When he sends to a Blueyonder addy from an account with a static IP the message arrives. When sending from an account with a dynamic IP though the messages disappear into the ether.
Seems that Blueyonder may be incorrectly looking up your ADSL IP address and rejected the email as it exists on an rbl (probably Spamhaus' PBL list).
Quote But if Blueyonder is incompetently using Spamhaus blacklisting I should still get a bounce, shouldn't I?
You'd have thought so unless their policy is to black hole these messages. If they're not adhering to convention in the first place though then there's every possibility that they are doing this.
Quote Is there a channel of communication with another ISP to correct this kind of mistake, or do I need to request a static IP?
It would be helpful if we had a bounced message but we'll see if we can get in touch with Blueyonder nonetheless. In the meantime you can change your IP address to static here.
11-07-2008 8:03 PM
