Blue light on router no connection...
- Blue light on router no connection...
23-10-2020 11:32 PM
Re: Blue light on router no connection...
24-10-2020 10:11 AM
@Clarebear1 Welcome to the forum.
Assuming that you can still use the Ethernet connection.
The official answer will probably point you here. https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510
The unofficial answer is to go onto an auction site and buy a BT Smarthub 6 for about £20 Setting instructions are here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
24-10-2020 10:17 AM - edited 24-10-2020 10:19 AM
24-10-2020 10:33 AM
There are various things that can cause your problem. The first question is whether you have any devices connected by Ethernet? If so, do these drop as well? This will confirm whether this is just a wireless problem or whether you are losing connection to the Plusnet servers. Can you check this by temporarily connecting s device by Ethernet cable if necessary?
You will always get better performance with Ethernet cabling, which I know you can't do with many devices. The Hub One currently has wireless problems that Plusnet have been trying to fix now for over a year. Hence many of us have given up on the Hub One and got a BT Smarthub.
Can this wireless issue affect all your wireless devices? Yes. Is this the cause of all your issues? It's difficult to know unless you follow one or other of the paths suggested above and report back..
24-10-2020 10:51 AM
