Blue light, no wifi
Juju330
Blue light, no wifi
The light is blue on my router, however, I have no internet connection. I rely on my wifi connection every day for work & cannot do anything without it so need it fixing ASAP
1 REPLY 1
Fixes: 390
Re: Blue light, no wifi
@Juju330  Welcome to the forum.
Have you miss posted and are on fibre, not ADSL or are you using a non standard hub? A blue light suggests that you are using a Hub One, which is normally reseved for fibre customers.
Either way the first thing to try is a factory reset by pushing a paperclip or similar in to the hub reset hole. Keep the switch closed for 30 seconds then leave it to see if it sorts itself out.
