Blocked sites still accessible?
Cagney1994
Hi
I've got the T582n router and when I've added a certain site to block, other users can still access it. The strange thing is, it's only blocked on the device where I originally did the set-up from  Shocked
Any help ?
Thanks.
Fixes: 162
Re: Blocked sites still accessible?
Odd, not one I've heard of before. Have you looked at using Safeguard instead and see if that helps? https://www.plus.net/home-broadband/safeguard/
 Chris Parr
 Plusnet Staff
pwatson
What DNS servers are specified in the network settings of the devices that can access the sites?  Are they all set to use the router as the DNS server or are they perhaps set to use something else, such as Google or OpenDNS?
Cagney1994
Quote from: Chris
Thanks. I'll use that as you've suggested.
Quote from: pwatson
All devices are using the router to access the 'net.
