Blocked port?
- Blocked port?
Blocked port?
26-01-2008 1:39 PM
Im trying to connect to a CoD 4 server. But cant. I can ping the IP, but when I try and connect in game I get nothing. Wondered if maybe the port was blocked? It's port 28961 IP 193.200.158.48
Message 1 of 7
(1,136 Views)
6 REPLIES 6
Re: Blocked port?
26-01-2008 2:21 PM
nevermind
Message 2 of 7
(453 Views)
Re: Blocked port?
26-01-2008 3:29 PM
As far as I know the game has been added, there are some things we can do to find out what's going on if you wish. Please let me know if you change your mind.
Message 3 of 7
(453 Views)
Re: Blocked port?
26-01-2008 4:16 PM
Well the port isn't blocked, I can connect to a different server on that port.
And I can connect to a different port on the server above.
It just seems to be that combination of IP address and port thats causing problems. Its definitely correct. Any ideas?
Message 4 of 7
(453 Views)
Re: Blocked port?
26-01-2008 4:18 PM
The server isn't working properly? That's about the only thing I can think of. Sorry that's not too helpful.
Message 5 of 7
(453 Views)
Re: Blocked port?
26-01-2008 4:23 PM
What other ports are working on that IP, as I am getting connection refused (blocked on the remote side) from an off-network connection (ie, proving the problem outside of PlusNet).
Message 6 of 7
(453 Views)
Re: Blocked port?
26-01-2008 4:57 PM
28962 works from my end.
As far as I know the server is online. I'll get back to the guy that runs it and see if has any further suggestions.
Message 7 of 7
(453 Views)
