Block device on WLAN
- Block device on WLAN
21-03-2012 5:33 PM
PT
Re: Block device on WLAN
22-03-2012 9:45 AM
22-03-2012 9:57 AM
PT
22-03-2012 11:32 AM
22-03-2012 1:30 PM
22-03-2012 1:49 PM
22-03-2012 1:50 PM
22-03-2012 2:09 PM
22-03-2012 2:34 PM
attached is the command for the v6 and it probably isn't any different
22-03-2012 2:36 PM
Disable MAC address filtering on wifi (allow all devices except those explicitly denied)
:wireless macacl config control unlock
Enable MAC address filtering on wifi (lock for any device not in list)
:wireless macacl config control lock
:wireless add hwaddr aa:aa:aa:aa:aa:aa permission allow
Deny Wifi to specific MAC address (no need for filtering to be enabled)
:wireless add hwaddr aa:aa:aa:aa:aa:aa permission deny
22-03-2012 2:56 PM
might put the 582n I have in place and see if that's any more intuitive.
22-03-2012 3:11 PM
So if your existing network is say 192.168.001.nnn, then change the network settings on the device to be excluded to say 192.168.123.nnn
22-03-2012 3:25 PM
22-03-2012 3:34 PM
Set the WAP to your existing wireless configuration but on a different wireless channel number.
On your router change the existing SSID to something new.
Change all your other devices to use the new SSID.
When you want the excluded device to be enabled then switch the WAP on, and when you don't then switch it off.
Simples !
22-03-2012 3:37 PM
