Bit of a result!
- Bit of a result!
- « Previous
- Next »
Re: Bit of a result!
04-03-2013 3:27 PM
11-03-2013 7:22 AM
Have tried a cold boot of the router but it still connects at or around 3db noise margin,now would this be a case of the router giving up the ghost or something line based causing this?
.......Also,just noticed the PN profile now showing @ 14500.
11-03-2013 9:21 AM
11-03-2013 9:29 AM
If that is the case,when you see it Chris can up kick the profile again?
11-03-2013 9:48 AM
I've given your profile a nudge, that should take effect shortly. I can also see a high number of errors on your line, that would concern me to be honest. It's likely due to your low SNR. If you start to have any problems, it may need shifting up to 6db.
11-03-2013 9:54 AM
11-03-2013 9:58 AM
Looking at your graph:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13629958909462.png"/>
I'm not sure they are causing you huge problems.
11-03-2013 10:02 AM
11-03-2013 10:07 AM
11-03-2013 5:15 PM
No idea why it thought things were ok to drop me down 3db this morning.
18-03-2013 8:02 AM
Link Information
Uptime: 0 days, 0:03:23
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,220 / 19,232
Bandwidth (Up/Down) [kbps/kbps]: 1,221 / 17,834
Data Transferred (Sent/Received) [kB/kB]: 248.00 / 466.00
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 11.5 / 25.0
SN Margin (Up/Down) [dB]: 6.5 / 3.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 495,755
CRC Errors (Up/Down): 32 / 975
HEC Errors (Up/Down): 7 / 21,934
As you see,few errors popping up,tho as before not really noticing it with my usual net usage from day to day. Would fixing the noise margin @ 6db (if possible) help or like before,just leave it be and see how the cookie crumbles?
18-03-2013 8:57 AM
If the errors aren't causing you any issues whilst using the broadband, I would leave it as it is. I can fix your SNR to 6db if you prefer though.
18-03-2013 9:45 AM
18-03-2013 4:15 PM
- « Previous
- Next »
