Bit of Bother - "macbook" network piggybacked onto my network
- Bit of Bother - "macbook" network piggybacked onto...
Re: Bit of Bother - "macbook" network piggybacked onto my network
17-06-2008 8:28 PM
Yes they're easy to spoof but if there are two routers running WEP (for example) one with and one without MAC address whitelisting enabled which one would you hack into?
Like I said - one more hurdle to jump over. Just depends on how determined a hacker is.
Personally, I've got everything enabled (call me paranoid) - WPA2 with a strong password, MAC whitelisting and an unbroadcast SSID (which can also be sniffed out quite easily, I know).
My point is, really, why make it any easier for them?
17-06-2008 8:58 PM
(I am also paranoid - WPA2 with 63char password, MAC filtering, unbroadcast SSID, captive portal, seperate subnet for wifi, subnet limited to 6 hosts)
17-06-2008 9:31 PM
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
18-06-2008 10:29 AM
I have to admit to being naive, and initially not quite believing that someone would do that because we live in a small group of houses and I really didn't think that we would have any sort of problem. Obviously I was very wrong.
So far "Macbook" has disappeared and I shall use the password advice. As far as accidentally joining the network, I don't think so....the simple wep key I used was broken. Also, when I looked at the network set up, it was "Macbook" and something like "this pc is used to connect pcs to the internet".
From now on paranoia rules!
18-06-2008 10:43 AM
Don't know where I'd find info like that on anything connected to our network, apart from the MAC address, computer name and IP address - that's all the info the Netgear router gives you.
18-06-2008 7:56 PM
Within a few minutes the WEP connection will be cracked. If it's a script-kiddie he may try guessing all the simple and easy passwords that people use (like "password", "netgear", "ManUnited", etc) just for fun, in which case it may take longer than a few minutes.
Cracking WPA keys is more difficult of course and takes longer. WPA2 may be impossible (for now). Weak passwords remain the best hope for cracking an authentication scheme, even when the encryption algorithm is strong.
18-06-2008 9:14 PM
However, for the past 2 days he has not got back on.
The only thing I can do for the immediate future is be extremely vigilant and as I happen to be training some police tomorrow.............
18-06-2008 10:58 PM
Quote from: Old The WPA is so far not random, but is a random word.
WPA cracking involves brute force dictionary attacks. We're talking about crackers' dictionaries here, which also include pet names, celebrity names, and variations with numbers as characters; e.g. D4v1d_B3ck4m
What I'm saying is: there are no single random words, unless you make up your own new words, they're all in the crackers' dictionaries. Either you should use a long string of random alphanumeric characters, or use unrelated words as a passphrase in a random password generator to produce a hash.
Hope this helps . . .
PS. Just in case, has anyone in your household an applemac or iphone?!
19-06-2008 9:20 AM
Quote from: MickKi Guys, not broadcasting the SSID is irrelevant for a committed cracker.
I am well aware of this (I use NetStumbler alot), but only have disabled to prevent casual users attempting to connect (fills my log files up). Also, the list of SSIDs is quite long, as my coverage is made up of a number of routers
19-06-2008 10:21 AM
Quote from: stordoff ..... but only have disabled to prevent casual users attempting to connect ......
Exactly. Someone looking for a connection is more likely to 'try' a network they can see as that's more likely to belong to someone who has less idea about security.
Round here there are a dozen or so networks visible from time to time (not all at once - usually a max of 5 or 6 but sometimes more), including a recently appeared BT Openzone, which I think might have replaced one of the BT Home Hubs. Naturally, out of curiosity, I've tested them from my Macs to see if they're open or not (very easy to do from the Airport drop-down menu at the top of the screen). Some that used to be open now have passwords and some of the WEP one have been changed to WPA, but with all those visible to tempt people, I feel safer hiding our SSID.
19-06-2008 4:30 PM
I use a 24 random generated PW using upper and lower case and numbers, its a pain to key in if a friend comes around and wants to use the wifi connection but it seems to work. I don't transmit the SSID and switch off the modem/router when I am not on the PC or laptop, it saves electricity as well.
19-06-2008 6:03 PM
Why not save it in a text file (on a usb device) and copy/paste it as required?
21-06-2008 12:08 PM
Good advice!
Quote Why not save it in a text file (on a usb device) and copy/paste it as required?
I had heard of dictionary attacks and should have realised that no word is random really.
The "Macbook" is nowhere to be found now, and no one has an applemac or iphone in the household.
I have been looking around and saw "dinisnet" as a nearby network. That one has puzzled me.
You people are great helping the idiot's of us that get into bother it is appreciated. Ironically the cause of my bother was because I used a password for the router & forgot it, so I reset it and then forgot to re-secure the wireless network. The word "forgot" seems to pop up a lot.
Thanks for all your help, it is greatly appreciated. I obviously need to drink more red wine to stop the forgetfulness!
21-06-2008 12:12 PM
From experience it doesn't seem too effective - if i remember correctly
Quote from: Old I obviously need to drink more red wine to stop the forgetfulness!
05-07-2008 12:22 PM
As a matter of interest there have been no nearby networks lately.
However when unencrypted I saved a network stumbler file. 5 nearby networks, including one called "Free Internet" and 2 "macbook" plus hpsetup were all "peer", whereas mine was AP - (Access Point I presume).
What does this mean?
