Bit confused about Broadband phone call useage as I have never done this
silverfinch
Am on line late as I had to do a system restore after getting too eager to make myself 'safe' online and ran the Adware thing. After doing that I checked broadband usage and it said I had used 50.47kb on broadband phone calls. Very confused as I don't know how to make that type of phone call. I may have asked this before but can't recall the answer. Huh
RPMozley
Fixes: 5
Re: Bit confused about Broadband phone call useage as I have never done this
50 kilobytes is quite a small amount. So I would guess that was just some background data wrongly classified as broadband phone calls. Nothing to be concerned about unless that number increases by a large amount.
Maybe just keep an eye on the usage for a few days, see if it changes a lot. If nothing big after that time I think it would be safe to say you're clear.
That's RPM to you!!
Plusnet Staff
Plusnet Staff
Fixes: 5
I completely agree with RPMozley. Let us know if you notice any other irregularities.
Chris Pettitt
Cloud Environments Engineer
