Bit Torrent Traffic Managed on BBYW Pro?
- Bit Torrent Traffic Managed on BBYW Pro?
22-10-2009 9:43 PM
As I'm on BBYW Pro, I thought the download speed wouldn't be any where near as 'managed' as this, if at all. Typical download speedtests for me are around the 3.6 Mbps mark.
It's no big issue for me as I don't tend to do much in the way of those type of downloads, unless the odd period of streaming counts, which works fine.
Btw, apparently the test doesn't work with IE8.
Re: Bit Torrent Traffic Managed on BBYW Pro?
22-10-2009 10:02 PM
Quote Is BitTorrent traffic on a well-known BitTorrent port (6881) throttled?
* The BitTorrent upload (seeding) worked. Our tool was successful in uploading data using the BitTorrent protocol.
* There's no indication that your ISP rate limits your BitTorrent uploads. In our tests a TCP upload achieved at least 151 Kbps while a BitTorrent upload achieved at most 466 Kbps. You can find details here.
* The BitTorrent download worked. Our tool was successful in downloading data using the BitTorrent protocol.
* There's no indication that your ISP rate limits your BitTorrent downloads. In our tests a TCP download achieved at least 2776 Kbps while a BitTorrent download achieved at most 2930 Kbps. You can find details here.
Is BitTorrent traffic on a non-standard BitTorrent port (10009) throttled?
* There's no indication that your ISP rate limits your BitTorrent uploads. In our tests a TCP upload achieved at least 307 Kbps while a BitTorrent download achieved at most 569 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent downloads. In our tests a TCP download achieved at least 1204 Kbps while a BitTorrent download achieved at most 2831 Kbps. You can find details here.
Is TCP traffic on a well-known BitTorrent port (6881) throttled?
* There's no indication that your ISP rate limits all downloads at port 6881. In our test, a TCP download on a BitTorrent port achieved at least 3041 Kbps while a TCP download on a non-BitTorrent port achieved at least 1204 Kbps. You can find details here.
* There's no indication that your ISP rate limits all uploads at port 6881. In our test, a TCP upload on a BitTorrent port achieved at least 629 Kbps while a TCP upload on a non-BitTorrent port achieved at least 307 Kbps. You can find details here.
23-10-2009 3:19 AM
* There's no indication that your ISP rate limits your BitTorrent uploads. In our tests a TCP upload achieved at least 350 Kbps while a BitTorrent upload achieved at most 353 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent downloads. In our tests a TCP download achieved at least 628 Kbps while a BitTorrent download achieved at most 628 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent uploads. In our tests a TCP upload achieved at least 354 Kbps while a BitTorrent download achieved at most 353 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent downloads. In our tests a TCP download achieved at least 607 Kbps while a BitTorrent download achieved at most 628 Kbps. You can find details here.
* There's no indication that your ISP rate limits all downloads at port 6881. In our test, a TCP download on a BitTorrent port achieved at least 628 Kbps while a TCP download on a non-BitTorrent port achieved at least 607 Kbps. You can find details here.
* There's no indication that your ISP rate limits all uploads at port 6881. In our test, a TCP upload on a BitTorrent port achieved at least 419 Kbps while a TCP upload on a non-BitTorrent port achieved at least 354 Kbps. You can find details here.
Re:Bit Torrent Traffic Managed on BBYW Pro?
23-10-2009 10:36 AM
23-10-2009 6:29 PM
23-10-2009 7:37 PM
23-10-2009 7:47 PM
23-10-2009 7:52 PM
Quote from: Mand Was the download running at the same time as the test? The test may have impacted the download and vice versa. Are you seeing performance problems on BitTorrent generally?
Sorry, I meant that I expected the download part of the test to occur first, like with most normal speedtests. I don't use BitTorrent, just curious to see the result of the test.
23-10-2009 8:12 PM
Doesn't seem overly reliable to me.
23-10-2009 8:36 PM
23-10-2009 8:40 PM
24-10-2009 7:58 AM
Quote Results for your host (87.115.99.153 - 87.115.99.153):
* There's no indication that your ISP rate limits your BitTorrent uploads. In our tests a TCP upload achieved at least 207 Kbps while a BitTorrent upload achieved at most 304 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent downloads. In our tests a TCP download achieved at least 202 Kbps while a BitTorrent download achieved at most 243 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent uploads. In our tests a TCP upload achieved at least 263 Kbps while a BitTorrent download achieved at most 282 Kbps. You can find details here.
* There's no indication that your ISP rate limits your BitTorrent downloads. In our tests a TCP download achieved at least 209 Kbps while a BitTorrent download achieved at most 249 Kbps. You can find details here.
* There's no indication that your ISP rate limits all downloads at port 6881. In our test, a TCP download on a BitTorrent port achieved at least 251 Kbps while a TCP download on a non-BitTorrent port achieved at least 209 Kbps. You can find details here.
* There's no indication that your ISP rate limits all uploads at port 6881. In our test, a TCP upload on a BitTorrent port achieved at least 314 Kbps while a TCP upload on a non-BitTorrent port achieved at least 263 Kbps. You can find details here.
24-10-2009 8:05 AM
* Completed BitTorrent and TCP transfers using the BitTorrent port 6881:
Transfer Speed TCP Speed BitTorrent Conclusion
Download #0 251 Kbps 209 Kbps No rate limiting
Download #1 202 Kbps 203 Kbps No rate limiting
Download #2 208 Kbps 243 Kbps No rate limiting
Upload #0 291 Kbps 281 Kbps No rate limiting
Upload #1 302 Kbps 304 Kbps No rate limiting
Upload #2 207 Kbps 166 Kbps No rate limiting
* Completed BitTorrent and TCP transfers using the non-BitTorrent port 10009:
Download #0 209 Kbps 249 Kbps No rate limiting
Download #1 251 Kbps 208 Kbps No rate limiting
Download #2 238 Kbps 209 Kbps No rate limiting
Upload #0 263 Kbps 282 Kbps No rate limiting
Upload #1 294 Kbps 282 Kbps No rate limiting
Upload #2 288 Kbps 208 Kbps No rate limiting
* Comparing TCP transfers using the well-know BitTorrent port 6881 and the non-BitTorrent port 10009:
TCP Transfer BitTorrent port Non-BitTorrent port Conclusion
Download #1 202 Kbps 251 Kbps No rate limiting
Download #2 208 Kbps 238 Kbps No rate limiting
Upload #0 291 Kbps 263 Kbps No rate limiting
Upload #1 302 Kbps 294 Kbps No rate limiting
Upload #2 207 Kbps 288 Kbps No rate limiting
24-10-2009 8:22 AM
Download #0 2351 Kbps 2352 Kbps No rate limiting
Download #1 2353 Kbps 2285 Kbps No rate limiting
Download #2 2281 Kbps 2353 Kbps No rate limiting
Upload #0 720 Kbps 703 Kbps No rate limiting
Upload #1 718 Kbps 707 Kbps No rate limiting
Upload #2 716 Kbps 720 Kbps No rate limiting
Is BitTorrent traffic on a non-standard BitTorrent port (10013) throttled?
* Completed BitTorrent and TCP transfers using the non-BitTorrent port 10013:
Download #0 2331 Kbps 2351 Kbps No rate limiting
Download #1 2311 Kbps 2308 Kbps No rate limiting
Download #2 2338 Kbps 2326 Kbps No rate limiting
Upload #0 720 Kbps 716 Kbps No rate limiting
Upload #1 721 Kbps 720 Kbps No rate limiting
Upload #2 720 Kbps 721 Kbps No rate limiting
Is TCP traffic on a well-known BitTorrent port (6885) throttled?
* Comparing TCP transfers using the well-know BitTorrent port 6885 and the non-BitTorrent port 10013:
Download #0 2351 Kbps 2331 Kbps No rate limiting
Download #1 2353 Kbps 2311 Kbps No rate limiting
Download #2 2281 Kbps 2338 Kbps No rate limiting
Upload #0 720 Kbps 720 Kbps No rate limiting
Upload #1 718 Kbps 721 Kbps No rate limiting
24-10-2009 8:31 AM
