Billion Router?
- Re: Billion Router?
Billion Router?
05-08-2013 9:09 PM
I'm on PlusNet Fibre having migrated from BeThere ADSL in February. When at BeThere I used my own Billion 7800N router which worked well for me and specifically had features like being able to configure static DNS entries for the services around my home (i.e. a DNS name can be created to point to a LAN address).
Initially I tried the 7800N (including an update to the latest firmware and ensuring QoS was off) but could not get the same performance as the PlusNet supplied Technicolor router; I eventually worked out that I could get the Technicolor to remember DNS mappings...
at command line...
{admin}[dns server]=>host add name=jira addr=192.168.1.12 ttl=0
{admin}[dns server]=>host add name=confluence addr=192.168.1.12 ttl=0
{admin}[dns server]=>host add name=minecraft addr=192.168.1.12 ttl=0
but I still haven't figured out how to make these persistent so I'm starting to think about another router...
Any suggestions on a Router that would allow me to have my own DNS entries, has good wireless coverage and goes superfast?
at command line...
Message 1 of 7
(1,350 Views)
6 REPLIES 6
Re: Billion Router?
05-08-2013 9:13 PM
try the command saveall after making the changes
Message 2 of 7
(605 Views)
Re: Billion Router?
05-08-2013 9:54 PM
I have tried "saveall" but the settings do not survive a reboot.
Message 3 of 7
(605 Views)
Re: Billion Router?
05-08-2013 9:55 PM
have a read here http://community.plus.net/forum/index.php/topic,113213.0.html
Message 4 of 7
(605 Views)
Re: Billion Router?
06-08-2013 8:58 AM
Quote from: NivagSwerdna Initially I tried the 7800N (including an update to the latest firmware and ensuring QoS was off) but could not get the same performance as the PlusNet supplied Technicolor router
Just out of interest (as I have a Billion 7800 and not yet in a fibre connected area),
roughly what sort of figures were you getting for both the Billion and Technicolor routers ?
Message 5 of 7
(605 Views)
Re: Billion Router?
06-08-2013 8:17 PM
@ purleigh I use a Billion 7800 on my FTTC 80/20 service, Throughput i get 9.1 -2MB/s downstream and 2.4MB/s upstream i sync at the full rate here's a speedtest result.which is a little lower on the downstream side than it is early mornings
http://www.speedtest.net/result/2884957241.png
Message 6 of 7
(605 Views)
Re: Billion Router?
06-08-2013 8:22 PM
@ NivagSwerdna there is a trick of saving the routers config file,as a backup and then editing that file so that any qos throttling is removed and then restoring the edited file to the router, There was information on how to edit the file on the billion forum , I use the billion 7800 wired only version without issues
Message 7 of 7
(605 Views)
