Billion Bipac 7800N ADSL Router settings and also adding a 2nd router
- Re: Billion Bipac 7800N ADSL Router settings and a...
27-10-2011 2:07 PM
I've set it up with the default settings (PPPoA, VPI 0, Mux 38, NAT enabled, MTU 1492) and currently am getting:
7872 / 448 kbps nominally (actual is ca. 5000 and 300 kbps measureed using speedtest.net)
SNR (up/down) 22.0 / 5.6
Line Att (up/down) 15.5 / 30.0
It also is in G.Dmt mode.
I have a few questions that I'm hoping somebody may be able to help with:
1. Are there any settings that I need to modify to improve the stability or speed of my connection? (I've read that there are settings in a "hidden" Billion configuration page that can improve the SNR, etc).
2. Is it worthwhile to change the modulation from G.Dmt to ADSL2 or ADSL2+, or is this something that only Plusnet can do?
3. I'm thinking of setting up my old Netgear DG834N router as a slave to the Billion to try and improve the wireless signal throughout parts of the house that only get a weak signal. I'm thinking of either setting it up using WDS, or if that fails then I mght go to the hassle of running an Ethernet cable to the DG834N. Has anybody done this, or have any advice as to how to make it work successfully?
Many thanks in advance for your help.
Re: Billion Bipac 7800N ADSL Router settings and also adding a 2nd router
27-10-2011 2:42 PM
28-10-2011 10:59 AM
28-10-2011 11:05 AM
28-10-2011 11:18 AM
One further question - if you are moving from room to room, will your device (laptop, phone) automatically move to the SSID with the strongest wifi signal or do you have to manually reconnect?
Cheers
28-10-2011 11:30 AM
Maybe someone with more experience of this type of setup can advise further.
28-10-2011 11:40 AM
If you want to try WDS they need to be using the same SSID. However I'm not sure if iether the Billion or the DG834 will support WDS and quite often getting WDS to work with different manufacturers kit is tricky to say the least...
28-10-2011 12:22 PM
Quote from: plusman 1. Are there any settings that I need to modify to improve the stability or speed of my connection? (I've read that there are settings in a "hidden" Billion configuration page that can improve the SNR, etc).
You can try tweaking your SNR margin, though this is something that will require patience to see results as you will want to test each sync rate for a couple of days at least and it also takes time for the IP profile to update on PN's end.
The hidden page is http://192.168.1.254/snr.cgi
The explanations of what code to use is here: http://www.spaldwick.com/broadband/billion-7800n
Quote 2. Is it worthwhile to change the modulation from G.Dmt to ADSL2 or ADSL2+, or is this something that only Plusnet can do?
No, you can change the modulation, assuming that your exchange is enabled for it. However bear in mind that depending on your distance, ADSL (G.Dmt) may be preferable to ADSL2+ for the same sync speed:
[Image obtained from: http://www.internode.on.net/residential/adsl_broadband/easy_broadband/performance/]
Overall, the 7800N is a brilliant piece of kit, you will not be disappointed.
28-10-2011 12:26 PM
Quote from: plusman I've set it up with the default settings (PPPoA, VPI 0, Mux 38, NAT enabled, MTU 1492) and currently am getting:
Just saw this - you definitely must try ADSL2/2+ as your Line Att suggests you will get 14M+
28-10-2011 3:09 PM
I'll see if changing to ADSL2/2+ makes any difference . According to SamKnows I am 1.45km in a straight line from my local exchange - so more than that as the cable lies.
Cheers.
28-10-2011 3:25 PM
Is there something else I need to do to tray and get ADSL2/2+ ?
Cheers
28-10-2011 3:55 PM
Quote Is there something else I need to do to tray and get ADSL2/2+ ?
Sounds like your account has been set to ADSL1. PlusNet need to enable it for ADSL2+.
28-10-2011 6:40 PM
Quote from: AndyS The hidden page is http://192.168.1.254/snr.cgi
Thanks for the reminder Andy. I'm now syncing at 8128kbs and noise margin 5db
29-10-2011 10:59 AM
I've tried setting up my Netgear WG834N as a 2nd access point by setting it's IP to 192.168.1.10 and turning DCHP off and connecting it to the rest of my network via a Ethernet-over-power (Powerplug) connection. I've also set ti to a different SSID compared to the 7800N. If I have encryption turned off or set to WEP then I can see and can connect to the Netgear (and my laptop recives the same IP address as if it directly connected to the 7800N). However if I use any form of WPA or WPA2 encryption (so that it matches the rest of my network), the connection just disappears and I am unable to connect. I've also monitored the connection using Inssider or Network stumbler, and they see the Netgear's wireless connection disappear as well.
I had the same problem in the past when I tried to connect an old Belkin wireless router to the Netgear - worked fine with no encryption, but didn't work when I tried WPA or WPA2.
29-10-2011 11:10 AM
I see both in 'Network' as shown below.
