Billion 7800N
sjrinfroyle
Billion 7800N
Just ordered one of these, I couldn't resist Smiley
How is it for stability? My connection tends to drop at night due to the SNR and I was wondering if this would solve the problem.
Also, what do people on here think about it in general?
Thanks,
Smiley.
Fixes: 123
Re: Billion 7800N
With it's current firmware 1.06e and an artificiality induced SNRM of 5db  my 7800N is rock steady at 8128kbs.
Generally I am happy with it for broadband and Wi-Fi.
Customer and Forum Moderator.
sjrinfroyle
Re: Billion 7800N
Quote from: Strat
What is your attentuation and what do you sync at without the SNR tweaked?
Fixes: 123
Re: Billion 7800N
If I let the SNRM float to 6db then Downstream drops to about 8000kbs. I have had 8128kbs at 6db but had an occasional overnight resync which dropped it back to the high 7000's.
Curiously I have had no overnight resyncs with the Margin pulled down to 5db Undecided
Operational Mode	G.DMT
Upstream 448
Downstream 8128
SNR Margin(Upstream) 24.0
SNR Margin(Downstream) 5.0
Line Attenuation(Upstream) 19.0
Line Attenuation(Downstream) 25.0
sjrinfroyle
Re: Billion 7800N
Quote from: Strat
Upstream 448
Downstream 8128
Thanks Strat, how are the errors in relation to the uptime?
Fixes: 123
Re: Billion 7800N
System Up-Time 6 Day(s) 6 Hour(s), Stats attached below.
If you know how to get more detailed stats from the 7800N I'm all ears.
Re: Billion 7800N
A recent line fault dropped my SNRM down to 1.6dB and mine held the signal without a flinch and a sync of over 12Mbps. It's getting a reputation of being one of the best around. If you want a full set of line stats Routerstats now works with it as well.
@Strat...
Download the latest Routerstats..   earlier versions don't work.
For the router search text use this URL for the stats page   ...  http://192.168.1.254/status/adslstatus.html
Tick "Use source A", get the page and mark the stats that you want
Telnet:
login set to admin and password
Change telnet prompt to ">"
Change chipset command set to adsl info --stats, tick alternative data format.
sjrinfroyle
Re: Billion 7800N
Quote from: nozzer
That is very encouraging. I hope I get the same results on ADSL1! How close are you to the exchange and what are your full stats?
Re: Billion 7800N
I'll reply tomorrow....  Just off for a pint of Heavy!  Smiley
Fixes: 123
Re: Billion 7800N
Still no joy with Routerstats. I'll give it another try tomorrow. Cry
Routerstats Lite just works out of the box Huh
Re: Billion 7800N
Settings that work for me attached.
Fixes: 123
Re: Billion 7800N
Telnet stuff working with latest version (6.7a) but basic Noise Margin and Sync Speed pages still zero.
Never mind, the stuff I need is in the Telnet pages.
Downstream
Noise Margin:    5.1  dB
Connection Rate:  8128  Kbps
Line Attenuation: 25.0  dB
Power:            19.7  dBm
Max Rate:        8320  Kbps
SuperFrames:      30343699
SF (CRC) Errors:  796
Reed Solomon:    0
RS Corrected:    0
RS Un-Corrected:  0
HEC:              509
Errored Seconds:  883
Severe ES:        6
Interleave Depth: 1
Bitswaps:        108760
Re: Billion 7800N
I presume you've marked the noise parameters in the Get Page dialog?
Fixes: 123
Re: Billion 7800N
Thanks nozzer I missed that bit Embarrassed
sjrinfroyle
Re: Billion 7800N
Got my 7800N running now. Looking good so far.
