Big Bittorrent problems
- Big Bittorrent problems
- « Previous
- 1
- 2
- Next »
Re: Big Bittorrent problems
04-10-2007 10:52 AM
What happens if you try it when booted into safe mode with networking (needs to be safe mode with networking, safe mode on its own is useless). And use the router, not a usb modem when in safe mode. It'll help eliminate software issues.
Long shot I know but, everything is worth a go.
Message 16 of 22
(312 Views)
04-10-2007 11:30 AM
Yep PJ you're right, but I think he's tried the private IPs also and still can't get anything.
I think wires are just getting crossed with the private and public IPs for the OP, but they have tried the computers IP that he is connected to and having the problems on.
Message 17 of 22
(312 Views)
04-10-2007 12:14 PM
Don't stare out the window, the answer isn't out there!
Message 18 of 22
(312 Views)
04-10-2007 5:43 PM
Good luck. I will be wanting out too soon. I tried usenet to get a new Linux beta ISO file and plusnet are throtting. Looks like bye bye from me too...
Message 19 of 22
(312 Views)
04-10-2007 8:17 PM
I think it's all those kiddies that have got home from school, been fed and have an urgent desire to do their homework. But, inexplicably they need to check out youtube, myspace, video this and that on msn, facebook and other things I know nothing about.
(I'm only a parent, so these teenagers baffle me).
Message 20 of 22
(312 Views)
04-10-2007 11:46 PM
Reading the post its not clear whats happening it seems you are trying to port forward to your internet static ip which you dont do.
You have a static ip on the internet 212 etc and normally the router uses NAT so the ip of your pc is 192 etc (you need to set it to a static ip as DHCP wont work)
You need to forward the ports to your pcs ip which will be 192 etc.
It sound as if you are trying to forward the port to the internet ip.
It should be very simple to just forward the ports reboot the router and it should work.
Message 21 of 22
(312 Views)
05-10-2007 12:09 AM
labortius,
Here are a couple of screen prints which could be useful:-
From the SERVICES menu add a new service (I've called it AZUREUS) and define a (range) of ports for the service (see screenshot-1).
Then go to FIREWALL and specify a rule to allow this port to have access (I was unsure about the INBOUND/OUTBOUND thing so I was generous) - 192.168.0.5 is the PC which will have the bit torrent access - see scrennshot-2.
Message 22 of 22
(312 Views)
- « Previous
- 1
- 2
- Next »
