Big Bittorrent problems
- Big Bittorrent problems
03-10-2007 10:39 AM
Secondly, can I say I just want to get this to work, and do not intend to swamp the network at peak times. PlusNet are very clear about their policies, which I admire, and if 12am to 6am is an OK time to use bittorrent, then that's fine with me. I don't intend to get much past 3 or 4GB a month.
Anyway, I have a Netgear DG834G, and am trying to use BitComet 0.84 and or Bittorrent 6.0 (actually uTorrent, I think). However I try to set up my router, I have no luck, I can't get incoming connections. It does see peers and the tracker is returning peers, but no downloads are possible.
The Netgear setup won't let me type my static IP into the send to LAN server, only the computer IP 192.168.0.2, I don't know if this is the problem. I've followed the guide on portforward.com and they seem to type in their static IP, but it won't let me do that.
I've changed the listen port dozens of times, created new inbound firewall rules, disabled the plusnet broadband router, tried lots of new, well seeded torrents as tests, can anyone tell me what I'm doing wrong?
Thanks for any help,
lab.
Re: Big Bittorrent problems
03-10-2007 10:44 AM
The IP address that you are to enter into the LAN server/port rules is indeed your IP address for that computer. Have you tried to set the IP requested on the router to the one you are attempting to use BitTorrent on? If not, then try that and create the inbound firewall rule to allow port forwarding on the port BitTorrent is using.
03-10-2007 12:18 PM
My static IP is 212 etc etc, but the router setup will only let me put in 192.168.0.1 and 192.168.0.2, and that's it, otherwise it complains it's illegal and deletes it.
Sigh. BitComet gives me a gray light, but sometimes says that 212 etc is blocked, so I think this is where the root of my problems lie. Should I go back to a dynamic IP address and see if this helps?
Thanks,
lab.
03-10-2007 12:26 PM
Just to clarify, when you are setting up rules for specific machines, you do it with the IP provided by the router/manually set up, not your IP provided by PlusNet (the rule would be bound to 192.168.0.2, rather than 212.etc)
03-10-2007 12:33 PM
Is everything else working fine?
03-10-2007 12:38 PM
I've tried 192.168.0.2 (that's my machine IP address). Using that IP address is blocking me off. I've told Netgear setup I have a static IP and given it it. I can put the static IP under WAN, but not LAN, so that's what I've done.
Jameseh,
utorrent on port 19900 and any other tells me the port isn't open when I test it, even though this port is specified in my inbound firewall rules, and the incoming connections light stays yellow (just like Bittorrent)
Thanks,
lab.
03-10-2007 12:41 PM
What happens if you're just using default settings on your router? No other rules applied and with it just set to connect you to the internet (ie: your automated setup wizard).
Be interested to hear if there is some rule that you have set up that's causing the connection to misbehave on uTorrent.
03-10-2007 12:45 PM
03-10-2007 12:57 PM
The default setting it to block ALL inbound traffic, and it did that, so torrents worked.
My rules are to allow bittorrent on 19900, my LAN is put it as my machine IP, my WAN as my plusnet static IP.
I tried to put in a DMZ last night, no luck, tried creating a new rule to allow everything inbound through, no luck.
I still get nothing even with my Thomsun Speedtouch 330 USB modem I tried yesterday.
Actually, one of my torrent has started up, it's on 70% and I've got a whopping 2.4Kb/s! (Everyone else is on 20 to 40).
Like I mentioned, I've tried half a doxen popular files as tests with no luck. My other two torrents, with 9 seend, 467 peers, and 8 peers 0 seeds have been stuck doing nothing for hours.
If I don't have any luck I have a spare BT modem I'll try this afternoon after I get it from the loft...)
03-10-2007 1:25 PM
B.
03-10-2007 1:48 PM
Thanks, I tried this, WAN set to ANY (default) and my staic IP deleted.
Still no incoming connections!
Argh!
03-10-2007 1:54 PM
Delete all the rules in the router.
Go to the UPNP section of the router and ensure that UPNP is enabled. Save the setting, then go to Diagnostics->Reboot Router
In uTorrent, go to Options->Connection and ensure that "Enable UPNP Port Mapping" is enabled, and "Add uTorrent to Windows Firewall Exceptions" is enabled.
Try to connect to a torrent and see what you get
B.
04-10-2007 7:48 AM
04-10-2007 9:41 AM
04-10-2007 10:17 AM
I rechecked, the plusnet firewall is still off (I turned it off yesterday once I found it existed).
I have deleted all the rules.
UPNP in the router was enabled, and I have rebooted the router.
Enable UPNP port mapping and add utorrent to windows firewall exceptions is enabled...light stays yellow, at my site end.
BT HGV2700, Netgear DG834G, Speedtouch 330 all have same result. Heck I have the Speedtouch with no windows firewall and no firewall at all, still no joy with Azurus 3.0.3.0, utorrent 1.7.5, Bittorrent 6.0. I give up.
Thanks for all the help though, everyone.
Chris, I've poured over that page, it won't let me put in my static IP (it starts 212 so it doesn't accept it, plusnet gave me that static IP.)
I'm on my way to ask for a MAC code. Five days ago with Zen I never had these problems. Time to move on, I think. Wish me luck.
lab.
