Better access to BT speed tester !
shutter
Fixes: 65
Just running my Monday Morning BT speed test......
it now says "there is a 1 hour minimum wait between successful speed test !
Yippee !....... Cheesy
5 REPLIES 5
coastergrotto
Re: Better access to BT speed tester !
You are right.  Thanks for the heads up.  That is good news.
tobykim
Only thing we need now is for it to work properly and give the correct results
W1ngD1ngs
I only noticed the speed tester falling over after the change!  Co-incidence...or....?  Crazy
Chris
Legend
Fixes: 169
Bob's just posted about this in the announcement section too: http://community.plus.net/forum/index.php/topic,83484.0.html
Oldjim
Resting Legend
Fixes: 63
Quote from: Strat
Thanks Bob Smiley
Shutter noticed the change also http://community.plus.net/forum/index.php/topic,83361.msg686366.html#msg686366
