Best way to get broadband fixed?
- Best way to get broadband fixed?
- « Previous
- 1
- 2
- Next »
Re: Best way to get broadband fixed?
24-01-2008 4:14 PM
Quote from: Jameseh Darron,
Do you currently have your router plugged in and powered up so I can run some quick checks at this end?
OK James,
Sorry for the delay, router will be on from 16:45.
I'll leave it on from then until I hear from you again.
Darron
Message 16 of 22
(455 Views)
25-01-2008 8:22 AM
Well, I don't know what's happened, but we noticed intermittent DSL lock yesterday from 22:45.
This morning at about 07:30 there was solid DSL lock and I had internet access for the 5 minutes I tried it.
Did someone do/change anything?
Darron
Darron
Message 17 of 22
(455 Views)
25-01-2008 9:00 AM
Hi Darron,
Not entirely sure if anything has been done, but I've seen two connections from you. 6 hours yesterday and 2.5 hours and ongoing today.
Certainly looks promising.
Message 18 of 22
(455 Views)
25-01-2008 9:09 AM
Hi James,
Certainly does look promising.
It would be good to know what's changed.
What happens next? Keep the support 'question' open and keep an eye on things?
Cheers
Darron
Cheers
Darron
Message 19 of 22
(455 Views)
25-01-2008 9:11 AM
Thanks Darron.
I've passed the ticket back to you. It'll close after 14 days, unless you send it back to us should the problem reoccur.
Message 20 of 22
(455 Views)
26-01-2008 10:41 AM
Things have improved, but still not ideal.
Friday 25th Jan.
16:00 - 21:00 no sync
21:00 - 22:00 sync lock OK & internet access
Saturday 26th Jan.
08:30 - 10:30 sync OK & internet access
Five hours of not being able to access the service isn't really acceptable, so I'd be grateful if someone can continue to look into this issue for us.
I'll leave the router powered up over the weekend in case you need to run further tests.
Darron
Friday 25th Jan.
Saturday 26th Jan.
Darron
Message 21 of 22
(455 Views)
26-01-2008 11:05 AM
You need to reply to the ticket to put the ball back in their court.
Message 22 of 22
(455 Views)
- « Previous
- 1
- 2
- Next »
