Best Router for coverage
- Re: Best Router for coverage
22-07-2013 1:42 PM
22-07-2013 7:00 PM
22-07-2013 8:39 PM
22-07-2013 8:59 PM
22-07-2013 9:37 PM
22-07-2013 10:18 PM
22-07-2013 10:26 PM
23-07-2013 7:06 AM
It's also very easy to set up & the GUI is very straightforward & comprehensive. I've never had to refer to the manual. Firmware updates are virtually fully automatic. I just click on "check" next to the firmware version box & the Asus does the rest.
23-07-2013 7:51 AM
23-07-2013 11:09 AM
Good luck, hope it goes OK.
23-07-2013 3:02 PM
23-07-2013 3:24 PM
Nick
29-07-2013 6:32 PM
i havent changed the factory default for the antenas so they are set at 80 out of a possible 200.
get fullsignal on 2.4mhz through 2 walls...well a ceiling then a wall.
only one dodgy spot in the house where the signal needs to go through 2 walls a set of stairs and another wall.
its a big house too
