Best Router To Buy For Plusnet
- Re: Best Router To Buy For Plusnet
12-10-2015 12:55 PM
Cheers
12-10-2015 1:01 PM
12-10-2015 1:29 PM
I did the following test BT Wholesale Broadband Performance Test and the results were
Download Speed: 12.79
Upload Speed: 1.03
Ping Latency: 39.50
Hope this helps
12-10-2015 2:42 PM
As for why it is buffering can you advise whether you are watching in HD or normal and is it the same on several devices
12-10-2015 2:55 PM
dick:quote
24-10-2015 5:10 PM
24-10-2015 5:26 PM
24-10-2015 6:04 PM
26-10-2015 1:43 PM
07-11-2015 8:49 PM
Quote from: Longliner My TG582 works fine on ADSL2+ at 3km from the exchange. Would there be any advantage to (say) Billion 7800n which I see widely available as folks go to fibre?
You'll likely see little to no difference (on an adsl connection) in downstream/upstream you may get better WIFI range etc with better antenna, wireless ac support etc depending on Router. I't's the same with VDSL (FTTC) if the router supports it then it will do fine. The only real reason you get an alternative router is for WIFI range, speed and usually better latency.
