Best Effort Service and Assured Rate Service
- Re: Best Effort Service and Assured Rate Service
30-03-2010 12:47 PM
Why are some users on Assured Rate and other aren't
30-03-2010 1:33 PM
30-03-2010 1:36 PM
30-03-2010 1:44 PM
Quote Note:
1. You can place your mouse cursor over the ‘help’ question marks indicated in the above screen
shot for an explanation to appear on screen.
2. If the End User does not subscribe to ‘Assured Rate Services’ then only the ‘Best Efforts’ results
will be displayed on the screen above.
Assured Rate Test
If the End User has subscribed to an Assured Rate service, the Performance Tester will test both
sessions i.e. QoS and Best Effort. If a QoS session is active at the time of testing then the Performance
Tester will use the already configured QoS session and Best Effort session for testing. However, if the
QoS session is not active at the time of testing then the Performance Tester will first test the Best Effort
session and then create QoS session for testing. After test completion, the original configuration will be
restored. The results page will show both, the QoS test results and the Best Effort test results as
above.
P.S please stop posting off topic posts - you will give the Plusnet experts an excuse for missing it
30-03-2010 2:26 PM
Is it those on the £5 extra max that get a higher throughput?
30-03-2010 2:40 PM
30-03-2010 4:22 PM
Its referring to the BT IPStream Advanced Services and Downstream QoS where a CP can request QoS enabled sessions to be applied to an end-users line, we do not provide this. BT install additional capacity based on forecasts from CPs that do provide this. There'll be documentation available on the Internet that provides a service description. HTH
30-03-2010 4:26 PM
30-03-2010 4:37 PM
30-03-2010 4:48 PM
30-03-2010 4:56 PM
30-03-2010 6:55 PM
i belive best effort is ment to give a minum of 3mb at the 4 peakest hours of the day
31-03-2010 11:48 AM
Everyone should just have the best effort results. Asbo on 21CN that should be above 2Mbps if you have a BRAS profile above 2Mbps otherwise it should be in line with the BRAS profile.
Plusnet Technology
31-03-2010 11:51 AM
http://community.plus.net/forum/index.php?topic=84775.0
http://community.plus.net/forum/index.php?topic=456.0
http://community.plus.net/forum/index.php?topic=84806.0
http://community.plus.net/forum/index.php?topic=84776.0
http://community.plus.net/forum/index.php?topic=584.0
Do you want any more
31-03-2010 12:11 PM
Quote from: Dawnrider
Download speed achieved during the test was - 876Kbps
Acceptable range of speeds is 400-2000 Kbps.
DSL Connection Rate :1440 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Assured Rate IP Profile for your line is - 1250Kbps
