Best BT Openreach ADSL faceplate?
- Best BT Openreach ADSL faceplate?
Re: Best BT Openreach ADSL faceplate?
27-04-2013 1:18 PM
27-04-2013 1:25 PM
Yep. It was just the adaptor faceplate. I just checked the wiring to the socket and that's all there was. I didn't have to wire the faceplate. It was just left like that by BT. The master socket was outside but he diverted it indoors.
27-04-2013 2:06 PM
Do all your Microfilters look like this?
27-04-2013 3:40 PM
27-04-2013 4:27 PM
27-04-2013 4:55 PM
27-04-2013 5:37 PM
27-04-2013 5:45 PM
27-04-2013 6:16 PM
OK, just keep an eye on that SNRM periodically, if you see any step changes, post up the full DSL stats and if you know of anythjng that was switched on or off when the SNRM changed.
Do a wired speedtest when you get a chance, see if that's a bit closer to 6Mbps.
03-05-2013 11:37 AM
Speed seems to be remaining constant at 5.6ish mbps.
I've managed to connect up via Ethernet today and this is the wholesale test results.
. Best Effort Test: -provides background information.
Download Speed
5.79 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.79 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.09 Mbps
Upload Speed
0.33 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.33Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
These are the current DSL router stats
Uptime: 7 days, 16:50:11
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,903
Data Transferred (Sent/Received) [GB/GB]: 1.67 / 14.45
Output Power (Up/Down) [dBm]: 12.9 / 0.0
Line Attenuation (Up/Down) [dB]: 27.0 / 49.0
SN Margin (Up/Down) [dB]: 20.5 / 3.1
Loss of Signal (Local/Remote): 5 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 24,986 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 113 / 79,755
HEC Errors (Up/Down): 43 / 170,607
I'm on Gateway pcl-ag01
I will try to change Gateway now but shouldn't I be seeing a little bit more speed now I'm wired?
03-05-2013 11:45 AM
Download Speed
5.68 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 5.68 Mbps
Upload Speed
0.33 Mbps
0 Mbps 0.45 Mbps
Nothings really changed so is it worth keep trying different Gateways????
03-05-2013 12:23 PM
The purpose of doing a wired test, is to make sure you aren't getting an slowdowns as a result of the wireless connection, which you don't appear to be at this time.
The previous download speed result 5.79 is pretty to close to the maximum you'll get with a 6Mbps profile, you will, as you've just found get slightly different results each time which will depend on Tester and Network traffic at the instant the test is run.
Looking at the stats, you've had no loss of sync speed still at 6903 with an uptime of nearly 8 days. But what is concerning is the SNRM which has varied and is currently down at 3.1dB, that's a large variation when there's been no loss of sync. Also the Upstream speed result is not good. So something is not right somewhere.
That sync speed and noise margin don't look as good as those in reply #14 although the errors are much better. It seems as though the filter arrangement you had for reply #14 gave better speed/noise margin results.
You could try following the advice I gave in reply #22 and try the previous filter arrangement and see what the stats are showing then.
03-05-2013 1:19 PM
Ping is now 41ms via a wired connection. SNR is 6dB. What is the significance of the SNR? Lower the better and faster?
03-05-2013 1:32 PM
03-05-2013 1:41 PM
The ping is back to 26ms on my PC wireless connection so will keep an eye on it. Will do some streaming and downloading again and post my stats on here again.
