Best BT Openreach ADSL faceplate?
Damian78
Hi chaps,
A BT engineer replaced my master socket last year for a all in BT Openreach socket. My speed went up to nearly 6.7mbps from 5.
Sadly the filter died about 2 months ago. Ordered a replacement off eBay but whilst it all works and looks the same my speed is never more than 5.6mbps now.
I want to keep the Openreach face plate but can anyone recommend a better clip in filter or a link to the official BT ones that may boost my speed again?
74 REPLIES 74
x47c
Re: Best BT Openreach ADSL faceplate?
The two I've seen recommened are:
ADSLnation one
http://www.adslnation.com/products/xtespec.php
ADSLnation all now part of Tandy UK
Pressac unit from Clarity.it
(possibly Pressac make the genuine branded BTOR units)
(you need the long screws: the NTE5 units take M3's)
http://www.clarity.it/xcart/home.php?cat=262
They work on slightly differing principles too complex to explain in a non-tech forum (even if I could remember them myself!) but do basically the same thing
Damian78
Thanks.
Gone for the Pressac one 🙂
HPsauce
The new-style VDSL interstitial plate is without doubt the best.  Cool
I "think" that's the one you've chosen.  Undecided http://www.clarity.it/xcart/product.php?productid=16215&cat=262&page=1
darklight
@Damian78
Plzz let us know how you get on with the replace filter face plate, if it makes any difference in speed.
Damian78
Will do. Should be here on Thursday.
Hoping it can return to 6.7mbps 🙂 Doubt it though but only £12. Been recommended to reset my SNR. Its about 3dB now I think.
darklight
If you wanna reboot router do it around 1pm to 3pm.
Damian78
Ah right. Best to do that instead of asking PN? Can do it at weekend if so
Anotherone
Champion
Fixes: 21
If you are on 21CN and your SNRM is around 3dB, then a reset will not help. It sounds like the current filtered plate was not the same quality as the original. The Pressac one - vDSL/xDSL should solve your problem, but do let use know, posting your full ADSL stats from your modem/router will give the best picture.
Damian78
Yeah. I am 21CN ADSL2+ I think.
Will post the DSL stats tomorrow then wait for the replacement. This is becoming a very helpful forum 🙂
Anotherone
Champion
Fixes: 21
What do you mean "becoming"  Tongue  Grin
Damian78
Ooops!  Tongue
adamwalker
Fixes: 221
Hope the replacement goes to plan, let us know if you need any help from our side after that.
Adam
 Adam Walker
Damian78
Thanks.
Will post current stats and speed later today.
Damian78
Current ping is about 41ms and max average speed is 5.52mbps and upload 0.32mbps.
Here's the routers stats:
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 7,795
Data Transferred (Sent/Received) [MB/GB]: 66.97 / 1.91
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 27.0 / 49.0
SN Margin (Up/Down) [dB]: 21.1 / 3.1
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 29,479 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 47 / 789,829
HEC Errors (Up/Down): 21 / 315,387
Is this ok?Huh
