Benefits of Plusnet Extra.
- Benefits of Plusnet Extra.
15-02-2011 5:18 PM
Hello all.
I am currently on the Plusnet Value package.
My exchange (Stepps) is NOT enabled for ADSL2. Therefore my question is this.
Other than gaining a 60 gb download limit, would there be any other benefit if I upgraded to Plusnet Extra? Am I correct in assuming that I wouldnt notice a speed increase as my exchange is not ADSL2 enabled. I currently get almost 6MB on Plusnet Value.
Thanks in advance.
Thanks in advance.
Message 1 of 2
(535 Views)
1 REPLY 1
Re: Benefits of Plusnet Extra.
15-02-2011 5:47 PM
First and easy answer - you can get ADSL2+ on Value if your exchange supports it
Second - the only speed increase would be on some of the downloading protocols http://usergroup.plus.net/prodcomp1.php
Message 2 of 2
(220 Views)
