Belkin routers
- Re: Belkin routers
Belkin routers
17-09-2011 8:04 PM
Does anybody own a Belkin router with interleaving off, the reason I am asking is because I have interleaving off and this is what my router page says
ADSL
Type Interleave Path
Status SHOWTIME
I have done a bit of googling and as I understand it next to "type" it should say "fast path" if interleaving is off. I don't know if this is correct or not.
I had interleaving turned off a few months back and my ping went down to 15, Last week interleaving was turned back on before I could say I didn't want it turning back on and my ping went to 25. Yeterday interleaving was turned off again and my ping has gone up to 35.
Thanks for reading
James.
ADSL
Status SHOWTIME
Thanks for reading
James.
Message 1 of 4
(2,646 Views)
3 REPLIES 3
Re: Belkin routers
17-09-2011 10:40 PM
Hi james,
I too have interleaving off, according to PN support. It is stil being reported as below I believe it must be a belkin glitch. PN can advise you directly if interleaving is on your line or not looking at their line details.
Podman
ADSL
Status Show Time
Downstream Upstream
Data Rate (kbps) 6624 445
Noise Margin (dB) 3.0 25.3
Attenuation (dB) 42.3 26.0
Output power(dbm) 19.5 12.4
Podman
ADSL
Status Show Time
Downstream Upstream
Message 2 of 4
(552 Views)
Re: Belkin routers
18-09-2011 10:37 AM
Thamks podman,
It seems Belkin have cut a lot of corners on their recent routers, the hidden pages being the major one but maybe they will fix this in time with a firmware update. The routers though are spot on IMO with a lot of options for security and such.
I will wait until Monday then maybe find out if Interleaving is OFF or on AUTO, I am pretty sure the fauts dept said it was on AUTO.
Message 3 of 4
(552 Views)
Re: Belkin routers
18-09-2011 2:20 PM
hi JamesM,
you don't need to wait until Monday Pn>n support are abble to look at your line at any time and tell if interleaving is on or off.
Also auto means it might not actually be off but rather your line is placed in a state where by it has been turned off but can came back on the instant any issue arrises hence the title auto. i am assured that it can be set to OFF / OFF and not OFF / AUTO
PN may be willing to do this depending on your stats this is what I was offered and as you can see interleaving is still recorded by belkin as on. it looks like with belkin depsite the useful features of the routers such a print server etc. we are to remain in the dark re our line stats.
Message 4 of 4
(552 Views)
