Belkin N300 Router
Mayfly
Belkin N300 Router
Sorry for being a dummy.. Sad
Is this compatible with 21CN exchange? - the techy bit on the Belkin website says it has an 'integrated ADSL2+ modem' but on the box it only mentions ADSL.
mushy
Re: Belkin N300 Router
I would expect so but if you post the model number you should get a better answer.
Mayfly
Thanks it's a F9J1002v1
apjashley1
Yes, it does - I have this as a spare router and it works fine
Mayfly
Thank you for your help, that's good to know.
